TwinTurbo.NET: Nissan 300ZX forum - Throttle body butterflies...
ZTurboFan
on December 17, 2009 at 9:37 PM
Re: are your throttle plates opened? it seems you are
posted by tognot
on December 17, 2009 at 08:27 PM
If his butterflies (or just one of them) was stuck partially open, his car would stall due to it getting that extra air when it should not.
Running out of time to get Z sorted out
17:38:32 12/17/09
Re: Running out of time to get Z sorted out
WazTTed
17:57:17 12/17/09
Re:
18:33:33 12/17/09
before, the idle screw was threaded in pretty far, I tried
18:37:35 12/17/09
Just double checking -- when messing with the idle
jzack
19:38:37 12/17/09
I did not, I believe it can be turned off via Datascan tho
20:00:49 12/17/09
Just mentioning because that's the procedure for
jzack
20:50:20 12/17/09
Re: Just mentioning because that's the procedure for
22:23:13 12/17/09
Just for grins -- disconnect the TPS and then the
jzack
16:33:26 12/18/09
Re: Re:
WazTTed
20:58:22 12/17/09
Just finished running the "hunting" checklist from FSM
19:48:27 12/17/09
datalog once warmed, driven slowly around the block
19:58:44 12/17/09
tognot
20:27:48 12/17/09
Throttle body butterflies... -
ZTurboFan
21:37:48 12/17/09
the air leak could easily be responsible for your idle
surfer31337
20:30:36 12/17/09
how can I know if I have resolved the high idle if it wont
22:26:38 12/17/09
OK. this is EXACTLY what you should do (in this order)
surfer31337
23:19:43 12/17/09
Yeah, and I really like #1.
ZTurboFan
00:41:15 12/18/09
Re:
02:23:37 12/18/09
One thing I found
Stadsport (PHX)
20:38:16 12/17/09
@#$%ing FUEL LEAK.......puddle forming under the car
22:17:10 12/17/09
Sort of same boat.
Jehannum
12:54:28 12/18/09
RESOLVED....finally
02:00:14 12/19/09
So after you repulled and fixed the fuel leak, your
BoneZ
09:31:17 12/19/09
as luck would have it, I am back again with high idle
11:46:39 12/19/09
update: seems I have a sticky throttle that I cant figure
16:56:01 12/20/09
Re: update: seems I have a sticky throttle that I cant figure
WazTTed
18:49:08 12/20/09
yes, I said in the post it wants to stick around 2k after
19:14:02 12/20/09
